Need help building...
Old Sep 8, 2006 | 06:22 PM
Tappin' 2.9's Avatar
Tappin' 2.9
I'm trying to add some more power to my 91 2.9. Any suggestions? I can't seem to find any performance parts other than cams and headers. Any help is appreciated... thanks.
Old Sep 9, 2006 | 02:01 AM
TigerDan's Avatar
TigerDan
Hi and Welcome to FTE! Please take a moment to check out the Guidelines as they contain important info you'll need when posting on the site:
https://www.ford-trucks.com/guidelines.html
Unfortunately, there's just not too much available in the way of bolt-ons for the 2.9. Headers, cam, cold air intake, that's about it. Anything more will require some machining and fabrication and modifications inside the engine. Some people report a slight power increase by using an early 2.9 throttle body (they were slightly larger) and you could always rework the heads, port them and install larger valves. (I don't think I'd bother putting the effort into stock heads though, I'd use aftermarket World Products heads.) Some later 2.9s had MASS Air as well, which is a help when performing major modifications.
For the money you'd put into it, you'd be better off swapping to a 4.0.
