E7TE's
Old Sep 8, 2006 | 12:10 PM
david00f150's Avatar
david00f150
E7TE's
What are the flow numbers for the E7TE heads?
Old Sep 8, 2006 | 12:48 PM
ken75ranger's Avatar
ken75ranger
From our freinds at carbed ford.
http://www.carbdford.com/tech/flowdata.htm
Lots of good info in their tech section.
Old Sep 8, 2006 | 02:45 PM
Melchiah's Avatar
Melchiah
are they stock one or are the ported and worked if stock try to find gt-40s but if you want to put work into the e7 then ya they are good head
Old Sep 8, 2006 | 03:18 PM
david00f150
No, I'm keeping the heads stock for now, just want to know some numbers. I know that they are a good head.
Old Sep 8, 2006 | 05:48 PM
dmc919's Avatar
dmc919
dont mean to change the subject but can you use rollor lifters with all E7's?
Old Sep 8, 2006 | 08:59 PM
P51D Mustang's Avatar
P51D Mustang
I'm sure you mean roller rockers, not lifters. Yes, as long as they are pedalstal mount-bolt down. Additionally, any compentant machine shop can convert them to stud mount, adjustable roller rockers, with guide plates.
Old Sep 8, 2006 | 09:07 PM
P51D Mustang
Stock 289 through windsor heads are designed for high flow velocities, not high flow volume. Considering, the original engines were relatively small displacement, long rod engines, this made good sense from a low end tourqe output, on a stock level motor, perspective. If mid-range tourqe and horsepower production are the the goals, then the flow volume needs to be much higher, and will really wake these motors up.
Old Sep 9, 2006 | 03:04 PM
Tiggie's Avatar
Tiggie
Linky
I like this site because of the easy comparison of flow numbers.
Old Sep 9, 2006 | 03:48 PM
dmc919's Avatar
dmc919
no i meant rollar lifters, cause i know the head has to be a certain way in order to use them but i didnt' know if they used rollar lifters with all the engines that came with E7 heads
Old Sep 9, 2006 | 04:44 PM
P51D Mustang
E7's were used on HO roller motors, and non HO- non-roller truck motors, and roller truck motors.
