Just When I Thought....
Old Sep 8, 2006 | 10:08 AM
HOTRODSURFER's Avatar
HOTRODSURFER
had some issues with my 53 F250 over heating,flushed the raditor/cooling system replaced hoses and stats(160 degrees) drove about 50 miles with water and prestone coolant flush added with no over heating,on my home from work last night BOOM truck over heats! rad was full of crud again,gonn flush rad again,and back flush cooling system with prestone in line flusher any other suggestions im stumped !! had good flow through rad after i flushed it last week
PLEASE HELP!!!!
Old Sep 8, 2006 | 10:38 AM
Randy Jack's Avatar
Randy Jack
I suspect that the heating/cooling cycles loosened some crud, probably in the block or radiator/heater cores. The back flush is a good plan. Pull the thermostat and check to see if it got blocked causing the new overheat problem.
With all the time it sat, I suspect you may have to do this a few times before all of it is dislodged and flushed.
Old Sep 8, 2006 | 10:52 AM
HOTRODSURFER
kind of what i was thinking! on a positive note my truck runs great except fo the 4.83 gears! i
Old Sep 8, 2006 | 11:02 AM
uc4me's Avatar
uc4me
I had similar issues with my hudson pickup, Ive never seen an engine run that well with the amount of crud that was in the water jacket of that thing.
You might want to try this stuff:
www.safestrustremover.com
I was installing a new radiator so looped the water pump back into itself, filled up the block (coolant system only obviously) with the rust remover and ran it up to temperature, shut it down and repeated 3 times in a 24 hour period and drained it, the stuff goes in looking like pee and cam out black and filled with crud. The inside of the water jacket looked like new cast metal and I never had any more issues with it.
here is a pic of the after, sorry I didn't take any before, but just imagine an engine that was 55 years old and run with water in it for most of its life
Old Sep 8, 2006 | 11:20 AM
HOTRODSURFER
cool thanks for the link,might give that a try!!
Old Sep 9, 2006 | 12:24 AM
bob s jr's Avatar
bob s jr
i had a old ford with similar problem it sat for yaers and rusted up pretty good a old blacksmith radiator repair guy to ld me to drain the antifreeze out of it put in 1/2 gallon of amonia and let it run at idle for about an hour let it cool and pull all the drain plug and flush the system out mine was rusted pretty good it took a couple of treatments but it pulled most of the rust and scale out of the block. pulled the rad out and he rod and boiled it and put good anti freeze in it never had overheating again.
side not amonia work good on getting surface rust out of the inside of gas tanks.
Old Sep 9, 2006 | 07:55 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
I agree with Randy don't get in a big hurry. I had the same problem on a 1963 I once had. I got the reverse flush kit and repeated as neccessary and ran Reverse Osmosis water in the system. My thermostat never did get plugged up. Maybe it is just the crud plugging the radiator. Also with the reverse flush kit you might try just using water with no chemical additives and see what comes out. One it starts coming out clean then go back and try the additive to flush more out.
Old Sep 9, 2006 | 11:53 AM
TheSovereign53's Avatar
TheSovereign53
The PO had to flush my 302 3 times to get it to stop overheating. Then it sat for 3 years, and didnt run. Hopefully I don't get it overheating again. But I agree with Randy's first post.
Old Sep 9, 2006 | 08:28 PM
HOTRODSURFER
ok guys back flushe cooling system till water was clear,did find my heater core plugged up with rust! so i disconected it for now -im just gonna replace it!
gonna see if she over heats tommorow!
