beating a dead horse
Old Sep 8, 2006 | 08:45 AM
indebt's Avatar
indebt
here we go again with the fuel economy thing, ok I just ran a tank and got just under 12mpg, I did not hot foot at all, I stayed under 2k rpm thru every gear, I have a 2000 psd, 6637, rwd, 3.73, 33's and a 4in lift, hypertech, 4in turbo back, what gives, what are some thing I can do the improve on fuel economy, are tired injecters the prob???, I just did a fuel filter change, oil change, tranny flush, what should check for next???? is there an in line fuel filter that could be old??????, thanks
Old Sep 8, 2006 | 08:50 AM
Kwikkordead's Avatar
Kwikkordead
Wow you have a 2wd and that low of mileage. Hmmmm.
No ideas here unless all your tires are really low and soft.
I replaced my injectors several months ago and the mileage didn't go up but maybe .5mpg.
Old Sep 8, 2006 | 09:28 AM
dpwilson's Avatar
dpwilson
Does the hypertech scan for codes? Pretty sure you have a problem with something. I have never seen under 14mpg averaging out a tank even pulling and hotrodding around. I'm sure somebody with similar experience will chime in soon.
Old Sep 8, 2006 | 09:40 AM
empiretc's Avatar
empiretc
before you decided to grandpa it, did you reset the computer? it makes the difference.
Old Sep 8, 2006 | 10:30 AM
jetdoc's Avatar
jetdoc
I'd say tire size and check the pressure. you would be surprised how much of a difference that makes.
Old Sep 8, 2006 | 08:55 PM
indebt's Avatar
indebt
I actually for this test set the pressure at 55 on all the tires with a digital gauge, so they were perfect. unfortunitly my hypertech doesnt scan, I might just take it somewhere to diagnose what wrong. (this sux)
Old Sep 8, 2006 | 09:00 PM
jetdoc's Avatar
jetdoc
Is you speedo recalibrated for the new tire size?
Old Sep 8, 2006 | 09:12 PM
DSun's Avatar
DSun
I have an 03 f250 4x4, and pulling the horse trailer I have gotten between 10.5-11 mpg. stock or with the hypertech. I don't have oversized tires or a lift kit.
Old Sep 9, 2006 | 07:57 PM
indebt's Avatar
indebt
It has not but I checked with a gps and Im off only about .10 fro every 10miles, it was way off when I had 38's, but it crused at 75 at 1800rpms, I love my truck just disappointed with mileage so far. Oh well guess I'll take the money im not paying in car payments and take it to a shop!!
Old Sep 9, 2006 | 08:02 PM
CAT_man_963's Avatar
CAT_man_963
The lift and tires will kill some milage - but on a 2wd that still sounds a little low... I'd agree with the other guys - something is a little off...
Also - I'd scrap that "drop in K&N" filter in your sig REAL fast!!
Old Sep 12, 2006 | 11:20 PM
indebt's Avatar
indebt
Do you guys think diesel kleen could help (clean things up)
Old Sep 12, 2006 | 11:30 PM
parkland's Avatar
parkland
I remember someone on here at on time metioning that the fuel pump was replaced on his PSD, and he got much better mileage.
Old Sep 13, 2006 | 01:02 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
I remember someone had replaced there HPOP half way throught a trip and got 4-5+ MPG gain on the way back.
Old Sep 13, 2006 | 03:21 AM
cowboylukas's Avatar
cowboylukas
How long of trips are you going on? That will affect your mileage as well. It seems that going empty for only 15 miles back and forth to work I get about 13 but if I drive further distances (less stops ect.) I get better gas mileage.
Old Sep 13, 2006 | 07:08 AM
hookd's Avatar
hookd
Whats your boost #'s? I don't have a lift but when I took off the 33's that came on the truck and went back to stock it brought it from 13 to 15 then I went hunting for a boost leak and now am at 18. Hopefully when I get some mods done this winter I can get it over 20. The warden is finally letting me feed my PMS
