1978 - 1996 Big Bronco
New Bronco owner
Old Sep 7, 2006 | 04:45 PM
Beast01's Avatar
Beast01
Question New Bronco owner
Any help would be appreciated. I have searched the forums and not found my set up. I have a 96' 5.8l with 6 inch lift and 35/12.50 17s with 4:88 gears and a stock tranny. While rolling down the highway my speedo reads 55mph at about 1800 or 1900rpm. With the set up I have does anyone know what my true mph and rpms should be? Thanks again for any help.
Old Sep 7, 2006 | 05:43 PM
helirich's Avatar
helirich
Your RPM's are correct. The diff gears and tires will not effect them. I have those gears, but I'm running 38" tires and my speedo is still 10% high. I think your going to want taller tires. if you want to figure out how much its off, just take it on the highway and note the mile marker signs and compare with your odometer. I would do it over at least ten miles.
Old Sep 7, 2006 | 05:47 PM
andym's Avatar
andym
The easiest thing to do is to re-program the PSOM as per the tech article here on FTE.
Old Sep 7, 2006 | 06:11 PM
MBBFord's Avatar
MBBFord
There is a site that can determin if it's right or not.
I'll take a look and try and find the calculator.
Old Sep 7, 2006 | 08:54 PM
Beast01's Avatar
Beast01
Thumbs up
Thank you for looking. I can't wait to see what you find. Headed off for the graveyard shift. I try back in the morning.
Old Sep 7, 2006 | 10:03 PM
MBBFord's Avatar
MBBFord
I had a few sites, but got a new computer and lost them, and this is all I could find right now.
http://www.therangerstation.com/tech_library/index.htm
Scroll all the way down, and on the right, then go up to sections to off road calculators and look at the first 5 or so(one might be about what you want).
Old Sep 8, 2006 | 05:34 PM
Beast01's Avatar
Beast01
Smile
Thanks for thr info. Looks like it does tire size and gearing seperately. I will probably take it in and have it calibrated. I am by no means a mechanic and I don't want to make matters worse. I have always wanted a Bronco, I am just going to have to get some of the little issues like this worked out. Thanks for your help.
Old Sep 8, 2006 | 09:02 PM
b4hntn's Avatar
b4hntn
Here is how I did it.
https://www.ford-trucks.com/forums/3...ht=speedometer
Old Sep 8, 2006 | 09:24 PM
greystreak92's Avatar
greystreak92
The guys have got you headed int he right direction. I'll just add that 4.88's with 35's are some tall gears even with overdrive in the transmission. The trade off is a ton of low-end power.
Old Sep 8, 2006 | 10:22 PM
NitrousAl's Avatar
NitrousAl
It's ironic, I tell everyone I know my "new" '95 5.0L Bronco 4x4 is a beast. I don't have a lift on it yet and I'm still running the factory 3.55 gears.
It's not a daily-driver to me, but all the mods I'll do to it will be 50-state legal.
Old Sep 8, 2006 | 11:55 PM
djjoshuad's Avatar
djjoshuad
50-state? over acheiver
sounds like a nice ride. reprogram that speedo and you'll be in good shape. on a '96 it doesn't matter what gears you have, the speed calculation is done based on rotation of the rear wheels vs. tire size.
Old Sep 9, 2006 | 12:33 AM
greystreak92
Just remember, you can only reprogram it 6 times.
