overdrive trouble
Old Sep 7, 2006 | 11:13 AM
bertman23's Avatar
bertman23
overdrive trouble
need some help. 1996 ford econoline van with a 5.0 e4od tranny. problem is the tranny will not allow me to turn the overdrive off for towing. have replaced the switch on the shifter lever, and checked the wiring and fuses. does anyone know what my problem may be. thanks
Old Sep 7, 2006 | 11:57 AM
Ruckus's Avatar
Ruckus
I would suggest calling your local Transmission Repair place and asking them. Most places are pretty good about giving you suggestions. Good Luck!
Old Sep 7, 2006 | 03:25 PM
Clubwagon's Avatar
Clubwagon
Does the "off" switch light when you cancel OD?
Its a common problem for the wiring in the column to fail and cause this problem. The fix is to replace the shifter.
Steve
'95 Clubwagon XLT
Old Sep 8, 2006 | 07:44 AM
bertman23's Avatar
bertman23
no the light does not appear when trying to turn it off. however the light does flash when you start the vehicle. i will still check the wires in the shifter. thank you. brett
Old Sep 13, 2006 | 01:45 AM
Desert-Rat's Avatar
Desert-Rat
Same problem in my 2004 V10 E350. Took to dealer, turned out to be a short in the selector / button.
Old Sep 15, 2006 | 12:08 AM
dallbright's Avatar
dallbright
OD problems-me too!
1995 E-250, 300 i/l 6, 4spOD, overdrive button does not work for me either. Tried button from son's '97 F-150, same buttom, mine works on his truck, his doesn't on mine, so mine is not the button.
Is there a relay somewhere? Fuses OK.
Old Sep 15, 2006 | 07:29 AM
Casey's Avatar
Casey
No relay. There is a common problem where the wires break where they enter the shifter handle inside the steering column. Remove the plastic cover from the steering column (3 screws) and you'll see the broken wires.
Old Sep 15, 2006 | 03:59 PM
dallbright's Avatar
dallbright
OK! Thanks Casey, I'll look there.
