5.4L problems.
Old Sep 7, 2006 | 01:57 AM
Lunchbox1980's Avatar
Lunchbox1980
5.4L problems.
I'm driving a 2000 F-250(4x4/4.10 gears) with a 5.4L and recently I've had some engine problems. Nothing major I don't think/hope.
When I go to accelerate the engine "chugs"(stutters, boggs down, feels like its being choked)... holding a steady speed almost always eliminates the engine stutter... at first I thought it was the coil packs but after talking with some friends and them test driving it they are convinced its a fuel problem. Since it was time for new plugs anyway I put new plugs in and it looks like the engine is running very lean.
The fuel filter is new(less than a week) so my friends and I are thinking its either one of the O2 sensors or the MAF... I have a full custom dual exhaust with no X,H,Y pipes... no cats... and my O2 sensors look pretty rough(too many trips to the woods/mud holes I guess)
I was hoping to get any ideas, maybe someone has had this problem before that could point me in the right direction.
Old Sep 7, 2006 | 05:45 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 7, 2006 | 05:01 PM
sednec's Avatar
sednec
How many miles do you have on your truck? I had similar problem cleaned maf and changed egr valve position sensor, drives much better
Old Sep 7, 2006 | 05:56 PM
ReAX's Avatar
ReAX
Did it start when you had the exhaust installed? If you haven't changed o2 sensors in the last 15-30K miles, you might as well take this opertunity to do so. A ballance pipe will help bottom end torque. Clean the MAF, pull the throttle body and IAC, give them a good cleaning.
Does the exhaust smell under load/accelleration (or reving while parked?)
Old Sep 8, 2006 | 01:00 AM
Lunchbox1980
My truck has about 130K. After checking around its just the drivers side bank thats running lean. I ordered an O2 sensor from summit should be here in the morning. Once I wrench that off and replace it I'll clean the MAF and see how she runs then.
Yes the exhaust smells a bit under load/accelleration.
Also on the chance that a coil has gone bad I ordered 8 Accel Super coils, only because I could talk them down to $15 a coil because of a misprint on thier webpage
The problem didn't start because of the exhaust because it ran fine when I bought it and the exhaust was already on it. I'm still looking around for a Ballance Pipe... I'd need an X-pipe but because of the tansfer case the 2 exhaust pipes are run so close together I need a very tight/narrow/close X pipe and I just haven't found one yet(haven't looked real hard though)
Old Sep 8, 2006 | 01:50 AM
Lunchbox1980
Also while I'm bugging you guys with questions... Can anyone reccomend a cold air intake kit that won't turn into a straw and suck water into the engine the first time I hit some deep water?
Old Sep 8, 2006 | 04:04 PM
LxMan1's Avatar
LxMan1
Try here for a X-Pipe http://www.drgas.com/store/product.p...2&cat=6&page=1
Old Sep 8, 2006 | 04:52 PM
ReAX's Avatar
ReAX
The k&n kit rides fairly high, see my gallery.
amusick10
Modular V8 (4.6L, 5.4L)
Jun 15, 2018 08:41 PM
ReluctantMechanic
Aug 29, 2014 04:03 PM
idontknowcars
1997 - 2003 F150
Feb 14, 2014 09:45 PM
savage250
23
Sep 14, 2010 10:58 AM
garbear17
1997 - 2003 F150
Jan 9, 2010 01:09 PM
