anyone out there that can help me plz ???
Old 09-07-2006, 12:49 AM
blackmagic84's Avatar
blackmagic84
blackmagic84 is offline
hi im looking to buy a 1986 f-150 four wheel drive.. automatic... with a 302 efi...
i was wondering would this truck have a c-6 in it or.. no and if theres a way to tell if it does or not ? .... and if it does have c-6 would thise bolt up to a 84 ... 351w H.O.... carburated
Old 09-07-2006, 08:07 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
It should have the C4 or the C6 and there is an easy way to tell. The C4 has a removable bellhousing. The bell is cast into the tranny case on the C6. You just gotta look under the truck and see. If it is behind a 302, then it will bolt to a 351W.
Old 09-07-2006, 07:10 PM
scottddove's Avatar
scottddove
scottddove is offline
my 86 4x4 has a aod transmission that is the most common if you find a 302 efi with a c-6 someone has had to have put it in it. I agree that I would rather have a c-6 but I dont think they came out that way.also a c-6 has vacum going to it where a aod will have a tv cable going to it off the throttle linkage. a c-4 will also have vacum as well.
Old 09-07-2006, 07:33 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
c4 wasnt an option in our trucks. they stopped being used in the late 70's. the C6 will be a 3 speed on the column shifter while the AOD would have OD on the shift selector
Old 09-09-2006, 06:10 PM
1980_f_100's Avatar
1980_f_100
1980_f_100 is offline
c4=11 bolt pan/ c6=17 bolt pan
Old 09-10-2006, 08:19 PM
Steamir's Avatar
Steamir
Steamir is offline
I believe that the C4 was last used in 81' It may be a C5. Count the bolts and the shape of the pan.
