rear end question
Old Sep 6, 2006 | 06:32 PM
Canadian Screw's Avatar
Canadian Screw
rear end question
what was the lowest gear in a 9 inch rear and what did thay come in i am on the hunt for a good rear end on the cheap some one told me about a f 350 with 4.88 gears how big of a rear end would that be, to big for a car or to wide any help would be great thanks
Old Sep 6, 2006 | 07:02 PM
andym's Avatar
andym
The lowest gears made were not available from the factory - aftermarket only.
An F-350 is going to have either a Dana 70, sterling 10.25 or sterling 10.5 - depending on the year. You'd have to get a pretty early F-350 to get 4.88 gears. I know in the 80's and 90's you could only find 4.10's from the factory.
It would also be an 8 lug full floating axle, which is pretty big for anything but a truck.
I guess the question is, what is this going into and what do you want it to do?
Old Sep 7, 2006 | 01:57 PM
Canadian Screw
well this will be going to be going in to an out law demolition derby car so size is not to much of a problem but i dont want a big 3/4 ton full floter i would like it to be a 5 or 6 bolt i am trying to get the lowest factory rear end gear i can find in something very strong so i can beat the crap out of it and not blow up the pumkin or bust an axle
Old Sep 7, 2006 | 02:23 PM
andym's Avatar
andym
A 9" is what you want then. The lowest common ratio that was offered was 3.50. 4.10's were offered, but you'll have a tough time finding one.
Old Sep 8, 2006 | 11:39 AM
Canadian Screw
i should just pick up a 9'' and go with after market gears then? if you know what i need to buy to make it work if i buy a 5.14:1 gear
Old Sep 8, 2006 | 12:32 PM
andym's Avatar
andym
If you want 5.14 gears, then you will definitely have to go aftermarket. You'd need to buy a ring & pinion and an install kit. Then take it to someone if you don't know how to do it yourself - it's not a shadetree job.
Old Sep 8, 2006 | 01:14 PM
Canadian Screw
do you know where i can order the gears and kit and how hard it will hit the bank? all your help so far has been awsome thanks
