hey i need to remove the lower rear door panels to install new speakers but theres no screws. Whats the correct way to remove them without breaking anything? \
Thanks alot
Just did that today, same reason. If you search the fourm there is a great thread with pictures on a late SC.
Quick instructions are
Remove 2 secrews holding window latch.
Pull top panel off, pull hard straight out working around the perimiter, I started at the top, worked well.
Remove the 2 push lock pins and the 2-7mm screws. For the push lock pins push the little "button" in the center in a bit, then pull them out.
