PCM failure?
Old Sep 5, 2006 | 08:33 PM
jsp0111's Avatar
jsp0111
Question PCM failure?
My 2000 7.3 died while stopping at a light. I havn't been able to start it. I replaced the CPM still doesn't start. i'm not getting a wait to start light and the fuel pump doesn't work when I turn the switch on. An Actron OBDll code reader won't communicate with the computer. PCM failure?
Old Sep 5, 2006 | 09:30 PM
cangim's Avatar
cangim
First off, welcome to the forums, when you get a chance check out the first thread for some trick stuff.
Now for current problem, have you verified all the fuses are good? Some OBDII readers will not read a Diesel PCM. What else does or doesn't work on the truck? Need some more info to help you out.
Old Sep 5, 2006 | 09:35 PM
jsp0111's Avatar
jsp0111
Thanks for the help, I've checked all the fuses, all good. Everything else seems to work.
