finding gear ratio
Old Sep 5, 2006 | 03:02 PM
Flyn66dtmn's Avatar
Flyn66dtmn
finding gear ratio
i know i've seen this post before so i know there are guru's out there that know how to figure out what the gear ratio is on a rear end without taking it apart. i wrote it down a coupla years ago and put it in a place where i could always find it. LOL. if anyone would like to part with this bit of knowledge again i would surly appreciate it.
Old Sep 5, 2006 | 04:12 PM
jowilker's Avatar
jowilker
Flyn, I have read about jacking up one wheel, or both wheels, dividing by 7 and multplying by 12. I'm cornfuzzed.
One sure way is to have a bud with you and on very level ground, hand roll the truck one tire revolution and count the driveshaft revolutions. Some folk like to take a string to the ds and help with the count.
This method is the way it works in real time, and garneteed to work everytime, on both open and LS rears.
John
Old Sep 10, 2006 | 04:48 PM
bob s jr's Avatar
bob s jr
jacking the truck up and turning the wheel would be safer same effect
Old Sep 10, 2006 | 08:53 PM
jowilker's Avatar
jowilker
How is that Bob???
John
Old Sep 10, 2006 | 09:04 PM
bob s jr's Avatar
bob s jr
had friend do that on slipped and rolled the truck over his hand broke it also quick way to see if it opened or limited slip was added
Old Sep 14, 2006 | 10:11 AM
MBBFord's Avatar
MBBFord
You can jack up the truck, turn the tire one full revolution, and count the number of rotation the driveshaft makes, and that should be your gear ratio, like previously stated.
But if your lucky, there should still be a metal tag on the bolts on the differental center, and is should be somthing like
3 50 4M3803HJ
Or somthing like that which means 3.50 gears made in blank on blank date.
Old Sep 14, 2006 | 10:24 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the Read First: FAQ thread at the top of the 73-9 forum for a real good method to find the gear ratio info.
meborder
Mar 8, 2014 09:28 AM
68Rookie
Jun 23, 2009 12:45 AM
mudslinging79
Bronco II
Oct 30, 2008 11:07 PM
tunaluvr
Oct 24, 2008 12:08 AM
kkoles2000
May 8, 2004 01:20 AM
