I just quickly glanced through my manual, and some of those pieces seem to be bolted at the "bottom" and Clipped at the areas closest to the defroster vents. If your Friendly with your dealer, see if they can get the "Exploded" parts diagram(s) for the dash areas in question. I'll also look and see if I can pull the particulars from mine that may help...
I did the exact same thing with alchol it left a big Mar where i rubbed it im in trouble can the pieces that hold the vents be removed and replaced or is that the Dash boards main assy
