NP 435 shift stick
Old Sep 4, 2006 | 09:16 PM
Ford_250's Avatar
Ford_250
NP 435 shift stick
I have a 435 and i want to have a different stick on it. that dog leg one has to go. is there another option or am i stuck with it.
Old Sep 4, 2006 | 09:41 PM
hoxiii's Avatar
hoxiii
There are two stock ford options. one is the dogleg, the other just come up and then bends towards the driver, but it won't work on a 1980+ truck. hits the dash in 1st gear.
Advantage of the older stickshifts is that is just a piece of 1/2" or so rod stock. cut the shifter off about 6" above the floorboard, weld a piece of rod or tube to it, heat it with a torch, and get it wherever you want it to be. There, infinitely many options.
Justin
Old Sep 4, 2006 | 11:28 PM
Ford_250's Avatar
Ford_250
ahah never thought of that. i think i just might do that
Old Sep 5, 2006 | 01:12 AM
hoxiii's Avatar
hoxiii
works pretty darn well, did it on a t-18 i had. curved the handle so it pointed staright back in neutral and then curved it towards the driver 90*. kinda like half of a T handle.
