head gasket
Old Sep 4, 2006 | 08:41 PM
bdunegan's Avatar
bdunegan
head gasket
i know i am probably looking at head gaskets, but have a 71 360 that has a head or intake gasket leaking slightly. not bad, but it is getting tiny (pin size) air bubbles back through radiator. not constant, but everyonce in a while. no coolant loss, or signs of oil in water or vice versa. truck has been sitting for several years, so i know gaskets are dried out. also has sign of fresh oil coming out under intake behind ps pump. is there anything i can add to this to prolong replacement, or is it best to go ahead and tear it down. maybe would quit after driving awhile? truck only has 39000 documented one owner miles, so definately worth the fix
Old Sep 11, 2006 | 01:05 AM
bob s jr's Avatar
bob s jr
pressure test the cooling system will tell you if you have a leak a few bubbles now and again will happen by the water pump flowing but you will have to pull the intake to fix the oil leak if its original probally cork gaskets no cure i know of if you can see rubber gaskets on the intake a couple table spoons of brake fliud in the oil might swell it up and slow it down for a while. but have the cooling systenm checked first for leaks might have to tear it down
Old Sep 11, 2006 | 01:14 AM
joes52f6's Avatar
joes52f6
I would probably go ahead and fix all the small problems now, just so you can keep them under control and not damage anything.
Old Sep 11, 2006 | 01:17 AM
bob s jr's Avatar
bob s jr
you can run it buy a shop and they presure test for an hour labor or you can buy a pressure tester through napa fo r about 80 bucks and use as need on all your rides
alleyoopster
1983 - 2012 Ranger & B-Series
16
Oct 17, 2019 09:54 PM
hivoltj
Nov 5, 2015 10:52 AM
Hellbringer
Apr 28, 2015 10:45 PM
trober_603
3.8 & 4.2L V6
Dec 17, 2012 04:03 PM
kat98
Oct 7, 2010 08:51 PM
