3208 cat
Old Sep 4, 2006 | 07:06 PM
rmiles's Avatar
rmiles
3208 cat
I was wondering if any knows for sure. I was under the understanding that for a year or two before the 6.9 was put in the trucks that the 3208 cat was offered as a option in the f-350 dulley 2 wheel drive thanks
Old Sep 4, 2006 | 09:14 PM
dmanlyr's Avatar
dmanlyr
3208 cats were never offered in a light truck. Meduim duty F550, F650 yes.
These are 10 litre medium duty engines, offererd in a natualy asprirated 160 hp all the way up to a 500 hp rating in marine turbo'd intercooled LIGHT operation usage.
Contimuous rated rating of about 300-325hp if you want durability. Limited RPM band, so more than the usual small truck transmissions are in order. Say a Clark 5 sp with a split rear end. 7 spd trans would also be good (not a 6 speed, either you give up low end, or high end or if wide ratio, then you can't get past the gaps between the gears if pulling a load)
David
Old Sep 4, 2006 | 11:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle
rmiles,
Welcome to FTE and the IDI diesel forum.
Old Sep 4, 2006 | 11:19 PM
ford390gashog's Avatar
ford390gashog
these were never offered in light duty trucks. they were only used in C series and L series. the F-500 and F-700 trucks did not get them.
