points
Old Dec 4, 2001 | 11:48 AM
deron292's Avatar
deron292
points
i have a 1964 F-100 v-8 292. It needs oints about every 3000 miles, is this normal or is their anything i can do to make them last longer or should i change the distribuitor to electronic ignaition.
Old Dec 4, 2001 | 11:59 AM
44dwarf's Avatar
44dwarf
points
Older fords are know to have this problem. There are three thing to do.
1) measure the voltage from the + terminal on the coil to ground. It should be ~10 volts running.
2) If voltage is high like 13.5 and higher check your voltage regualtor. If bad replace with a soild state unit. (autozone has two types one is short protected! spend the extra dollar for it = $11.95)
3) do step one again if its still high get a universal ballast resitor and screw it to the fire wall and cut the + wire from the coil and go to one side of the resitor and one the other conect the harness from the ign switch.
4) Or do what i did and use a MSD 6a box and never have a problem again. If an MDS is to much try a Petzitronic ignitor its a soild state converter kit for point distribs.
44dwarf
Old Dec 4, 2001 | 06:12 PM
jowilker's Avatar
jowilker
points
Good points 44, I think the Pertronics would be the best for the buck.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Dec 5, 2001 | 01:00 AM
truckfarmer's Avatar
truckfarmer
Post points
Old Dec 5, 2001 | 06:40 AM
William's Avatar
William
points
Install a Pertronix Ignitor instead of points (two screws and a couple of wires) and get on with your life. Maybe add a hot coil, flat cap, fat wires and a set of platinium plugs gapped at 60.
William in Atlanta
Old Dec 5, 2001 | 08:00 AM
44dwarf's Avatar
44dwarf
points
I only whent with the MSD cause I had it laying around. It did help my very worn out old s cyl. No more bucking and farting back out the carb and i picked up 2 mpg!
44
PS: JC Whitney has the Pet ignitoer units for ~$65 last i looked
