Need a little more info. What kind of box do you have and did you hook it up?
How do you know it's inop?
It should have a fuse on it somewhere.
Do you have a multi-meter?
Check your red wire (should also be the fatest wire) and see if you have 12 volts. Gonna have do some checking here and someone should be able to help.
Actually all you need is one of those little testers...you know...looks like a plastic screwdrive 'cept it's got a sharp point and a wire with alligater clip on one end and bulb on other. When you clip the clip to a ground, you stick a wire and the bulb lites if it's got juice.....12 volts
