e4od help
Old Sep 4, 2006 | 03:28 PM
samtye's Avatar
samtye
e4od help
i have a 89 f250 with the e4od in it. i serviced the tranny yesterday, and when i went to dump the fluid out of my drain pan, i found this little ball with a shaft on it. it measures about 1 inch round with about a 1 inch shaft on it. does anyone know where this belongs? please help.
Old Sep 4, 2006 | 05:46 PM
Blurry94's Avatar
Blurry94
Is it made of plastic?
Old Sep 4, 2006 | 05:59 PM
samtye's Avatar
samtye
yes it is and it has a o-ring around the ball. thanks
Old Sep 4, 2006 | 10:00 PM
Blurry94's Avatar
Blurry94
My guess is that it's the factoy plug for the trans dipsitck line. It is installed there to keep anything from falling into the trans, during the initial build, until the dipstick is installed. When the dipstick is installed, it'll push that "plug" down into the trans pan and that's where it sits until the trans fluid is changed....you can just toss it.
Old Sep 4, 2006 | 11:39 PM
samtye's Avatar
samtye
cool thank you so much. i cant believe that nobody has ever changed the fluid in this before. i guess it makes sense seeing how black the fluid was. thanks again
