Cruise control not working
Old Sep 4, 2006 | 03:06 PM
GA Strokin's Avatar
GA Strokin
Drove down to Birmingham and back this morning and the cruise control was not working. Checked the fuse and it was still good. I am taking a cross country trip in less than two weeks and it will be brutal without cruise control. Anything to look for specifically, so I don't have to take it to a dealer. My signature doesn't appear to be showing up, so just to let you know, it is a 2001 F-250 Crew Cab Powerstroke, manual transmission. We replaced the clutch this weekend, but there was only one cluster of wiring that was unplugged and we plugged that back in.
Thanks for the help!
David
Old Sep 4, 2006 | 06:40 PM
Uzumati's Avatar
Uzumati
Which Birmingham??
Self-Test Diagnostics — Excursion, Super Duty only
WARNING: This test is a key on engine off (KOEO) test only that is conducted in PARK only with the emergency brake fully engaged.
Enter the Self-Test Diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. FIVE ADDITIONAL FLASHES AT THIS POINT INDICATE A DEFECTIVE SPEED CONTROL SERVO. Release the OFF switch.
Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the "ON" switch is not depressed within five seconds after entering the diagnostic mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
NOTE: There will be a slight delay when the last button is pressed and the lamp flashes.
A lamp flash with the last button (SET/ACCEL) indicates that the STATIC test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
Flashes Source
2 Flashes BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped) is defective
3 Flashes Deactivator switch is open or circuit defective
4 Flashes Vehicle speed signal is out of range or circuit is defective
Immediately after the STATIC test, the speed control servo does a DYNAMIC test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the DYNAMIC throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the THROTTLE RETURNS BACK TO THE IDLE POSITION.
Old Sep 4, 2006 | 08:26 PM
GA Strokin's Avatar
GA Strokin
Birmingham, AL, coming from the Chattanooga, TN area. Actually, I ended up in Garden City, AL, I believe.
Would the above information change considering this is a manual tranny?
Old Sep 4, 2006 | 08:36 PM
piotrsko's Avatar
piotrsko
I'm guessing that clutch all the way to the floor and hold it there instead of park, (parking brake engaged please)
UHHHHH, I don't have a servo in my PSD, the computer just adds fuel when I need to go faster. Gawd I like solid state controls.
Old Sep 5, 2006 | 07:21 PM
GA Strokin's Avatar
GA Strokin
Never did get the "cruise" light to come on when trying to do this diagnostic.
Old Sep 8, 2006 | 04:57 PM
mikes econoline's Avatar
mikes econoline
just stumbeled on your reply on the cruise control post just wondering if this will work for 2003 econoline 250
thanx
mike
Old Sep 13, 2006 | 07:36 PM
GA Strokin's Avatar
GA Strokin
FYI - It ended up being the clutch switch.
