fuel pump 95
Old Sep 3, 2006 | 09:34 PM
paulgc's Avatar
paulgc
Question fuel pump 95
I need to replace the fuel pump on my 95 ford diesel. I have been told everything but tht right thing. I read the form on the 97 model how close is it to the 95. Help?
Old Sep 3, 2006 | 09:50 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's the same.
Old Sep 4, 2006 | 04:26 PM
paulgc's Avatar
paulgc
I am down to pulling the pump out. But I tried turning the cam until the pump pop up. It won't pop up. I would like to know how to set the cam eccentric so the tappet won't fall down in the engine.
Old Sep 4, 2006 | 04:54 PM
1997F-350's Avatar
1997F-350
you turned the crank with a ratchet and 24mm socket and it didnt lift the pump at all?
do you have the hoses disconnected, banjo fitting disconnected, fuel pump bolts out? try tapping on it a little.
Old Sep 4, 2006 | 05:02 PM
fordnut1985's Avatar
fordnut1985
The trick is to twist the pump (don't pull up), that will break it loose and then it will pop up when you turn it over.
Duane
