Starting problems
Old Dec 10, 2001 | 01:01 PM
EriktheRed's Avatar
EriktheRed
Starting problems
Hi again everyone,
I have started up my 66 for the first time in a couple of
years and have a question.
The first day it started and continued to idle, but cut
off when I pushed down the accelerator. The next weekend, it
would only run for a few seconds when putting some gas directly
in the carburetor. I am thinking there is something wrong with
either the carb, fuel pump, filter, or in the fuel lines. What is the
best way to determine this? (it is a 390/2bbl)
erik
66F100
Old Dec 10, 2001 | 05:24 PM
Rosati's Avatar
Rosati
Starting problems
Pull the carb and clean the needle and set and replace your accerator pump diaphram. Should run fine after that.
Krosati
[link:www.ford-trucks.com/user_gallery/displayalbum.php?&albumid=28|My User Gallery]
Visit my homepage at ClubFTE
[link:www.clubfte.com/users/krosati/index.html|My Homepage]
My friends say I'm too old to play with toys.
I need new friends
Old Dec 11, 2001 | 12:07 PM
airharley's Avatar
airharley
Starting problems
You may also want to change out your fuel filter and blow air back through your fuel line. Just disconect it at the fuel pump inlet and take the gas cap off before you do. Remember water is heavier then fuel and settles in the low spots.
Old Dec 11, 2001 | 10:10 PM
ducksbucksnbulls's Avatar
ducksbucksnbulls
Starting problems
I might drain the gas thats in the tank now. im not sure were ur from but
when you got year old gas where i come from it most likley is bad
let us know what u find
Old Dec 11, 2001 | 11:32 PM
glindley's Avatar
glindley
Starting problems
surfmon
Aug 21, 2015 03:28 PM
kutoutpic66
Feb 24, 2011 08:55 PM
'66f100boy
Jul 7, 2008 10:27 AM
bigred66
1978 - 1996 Big Bronco
Oct 5, 2007 12:16 PM
66Ford my baby
Aug 2, 2006 03:28 PM
