Few Questions
Old Sep 3, 2006 | 09:06 PM
BAJI26's Avatar
BAJI26
Question Few Questions
2000 Limited Ex Gas 2WD -
How many Quarts of Engine Oil?
How many Quarts of Tranny Fluid?
I read the tutorial about changing the Tranny Fluid... Does anyone have the Pics to go with it cause I'm betta at the pics wid the text.
Thanks in advance!
Old Sep 3, 2006 | 09:59 PM
Jetfixr's Avatar
Jetfixr
6 Qts. motor oil
just under 18 Qts. tranny oil
Please read about Mercon vs. Mercon V
The transmission is pretty easy. The oil cooler lines are on the right side. Make sure and use a clamp or the hose will come off.
Jerry
Old Sep 3, 2006 | 11:22 PM
BAJI26's Avatar
BAJI26
so its draing for the line itself? I saw 2 lines going to the same junction on the right side of the tranny, take that off and attach a hose to it to drain it?
Old Sep 3, 2006 | 11:48 PM
Jetfixr's Avatar
Jetfixr
Take off the line farthest from the engine put the clear hose on the end of the line with a clamp. The other line will stay on the trans I'm not sure what it is, it just runs up to the forward line.Your going to need a couple of oil pans with a total capacity of 20 Qts. to be safe. Put the other end in the oil pan and start the engine. Watch, the oil will be pumped through the oil cooler and into the pan. When you see air bubbles turn off the engine. Add 6 Qts. of fluid and do it again. When you have added 6 Qts for the third time reconnect the line and run the engine to check the oil level. Make sure there's oil on the dipstick, drive around to get the oil hot and top off. Checking the oil when it's hot. Pretty slick, I've never even removed the drain plug on mine.
Jerry
I hope this helps
