rear axle code
Old Sep 2, 2006 | 06:58 PM
RCrawler's Avatar
RCrawler
Question rear axle code
Looked at a 78 F150 2wd for sale. Had an axle code of 11A. I found that A is for p/s with tilt column. Any information on what 11 is. The only thing that I found is 11 is for a 2.75 axle, but what model? Has a Dana 44 which appears to be original, but I have never seen anything but a 9" in a 73-79.
Jason
Old Sep 2, 2006 | 08:18 PM
Mil1ion's Avatar
Mil1ion
are you sure it isn't 14 and not 11 ?
Where did you get the 11 code saying it's a 2.75 from as I don't have anything for 78 or 79 with 11 as an axle code ?
http://www.clubfte.com/users/mil1ion...ruckCodes.html
In 78 they already had codes 06 & 13 as a 2.75 ratio
In 73 74, there was a code 11 for the 3.50
and in 75 code 11 was the 4.11.
What are the last 6 digits of the Vin #.
Old Sep 3, 2006 | 12:39 PM
RCrawler's Avatar
RCrawler
I found it on a google search. Shows up as a 77 model year 2.75 in a 3300 lb axle. Not sure if it is accurate or not, figured it could carry over into later model years since I found nothing for 78. I found earlier models showed 11 with the same info you give.
I read the data plate twice to verify the number. I'll see if it is still for sale to get a VIN. Just had me scratching my head as I have never seen a 44 beyond 72 model.
Thanks,
Jason
Old Sep 3, 2006 | 02:56 PM
Jmudder79's Avatar
Jmudder79
My friend had a 44 in his 78 2wd. It had me kinda wierded out at first too. That was the first and last time I saw a rear 44 in a fullsize pickup.
Old Sep 3, 2006 | 08:07 PM
LxMan1's Avatar
LxMan1
I have seen them in a few different year trucks.
