I have a 1995 F250, 5.8L, auto transmission. When the key is turned to the start position, several annunciators illuminate but the engine does not turn. It starts fine by shorting the solenoid near the battery using a screwdriver. I replaced the solenoid and it still doesn't start from the cab. Also, the speedometer and odometer do not work, the dashboard lights do not work, the ABS annunciator stays lit, and it does not shift properly. I swapped the solenoid and it still doesn't start.
What are the odds of a bad solenoid straight from the box?
I have checked the fuse box and no fuses are blown.
Any ideas if everything is linked or just multiple simultaneous failures?
I am almost wondering about your ignition switch. This is not a valid suggestion, but worth a thought. Definitely an electrical problem, grab the haynes manual and start following wires. That is where I would start.
After rethinking this one you may have lost your dash ground or your body ground.
Check all ground wires at the dash and from the Neg Battery post to the body ground.
