engine storage
Old Sep 2, 2006 | 02:26 PM
psulik1's Avatar
psulik1
engine storage
Hello everyone. I have a 460 and a flathead that I need to store in my garage for at least 2 years. All the internals are out of them, just a bare block. How can I store them for an extended period of time without having them rust? Any ideas would be great. Thanks!
Paul
Old Sep 3, 2006 | 01:03 AM
airharley's Avatar
airharley
Several options come to mind....
Coat every square inch in wax, grease, or if you can find CPC (MIL-C-85054)
http://www.lhbindustries.com/lhbstor...?itemNo=954000
puts the parts in a cocoon for as long as you need it. Then put it to bed with plastic painter tarp.
Old Sep 3, 2006 | 01:50 AM
turbo2256d's Avatar
turbo2256d
chain saw bar lube is good for dissasembled parts brush it on spray it on.
Old Sep 3, 2006 | 06:47 PM
WILDEBILL308's Avatar
WILDEBILL308
Hi psulik1,
What ever you do don't use WD40 on aneything you don't want to rust, it is a water base. You might try the local militarey surplus place and see if they have cosmolean it is the best for long tearm storage I don't know if the CPC that airharley mentoned is the same. Cosmolean is what they perserve guns with for long tearm storage. I have cleand up stuf that had ben in storage since WW1 and still in perfect conditon.
Bill
Old Sep 3, 2006 | 09:15 PM
airharley's Avatar
airharley
Cosmolean and CPC are the same. CPC stands for Corrosion Prevention Compound.
Old Sep 3, 2006 | 10:31 PM
WILDEBILL308
Yes I know what CPC stands for there are several out there. I have used CPCs that varey from a light wax to stuf hevier than Cosmolean. I would call around and see if aney of the surplus stores have Cosmolean as it is one of most comon and usualey cheap.
Bill
