Building a tow rig?
Old Sep 1, 2006 | 03:04 PM
Dustin_86's Avatar
Dustin_86
Question Building a tow rig?
I want to make a good tow rig out of my 78 f250. It is a 2wd 3.73 Granny 4spd(np 435) RC long bed. It has dual pistion front calipers. A rear dana 60 HD 460 coils in the front. I have a rear spring setup with 16 springs on EACH side plus a overload.. Onboard air, It has Durango 315/70R16 D tires in the back and 235/ 85 R16 E tires on the front. What about 4.56 gears? The 6cyl stays OK.
I'm looking for any upgrades you'd recommend?
Shocks? Sway bars F/R, front air bags, Brake upgrades,Things to make it more stable?? Frame bracing?
PS the GAWR rear is 6,000lbs and front is 3150lbs GVW unknown.
Dustin
Old Sep 1, 2006 | 04:16 PM
FordPickup460's Avatar
FordPickup460
What do you plan on towing? It sounds to me like you have a nice setup already, besides that 6cyl With that 6cyl I recommend a lower gear, like a 4.11. With 4.56's you would'nt be able to keep up with freeway traffic.
I strongly recommend a trailer brake controller and the proper hitch also. Some west coast mirrors or simillar that stick out past your trailer will help out alot.
Old Sep 1, 2006 | 05:45 PM
Dustin_86's Avatar
Dustin_86
just about anything. I haul 500-5000lbs in the bed and haul between 2500-17,000lbs.
I'm looking at making it more "comfortable"I just want to build it so if I need a seriously capable rig I have it.
PS thanks for the comment
