High compression piston idea
Old Sep 1, 2006 | 02:18 PM
rusty70f100's Avatar
rusty70f100
I've got an idea for a high compression piston for the 4.0L. It's to use a 383 Chevy piston. Here's the specs:
http://www.kb-silvolite.com/performa...tails&P_id=222
I figure, since stock the 4.0L has a wrist pin diameter of .945", we could use a thicker bushing to take the small end of the connecting rods down to .9272" and use the Chevy size wrist pins. You would also have to bore the block .050" oversize to 4" bore to be able to do this.
As far as I've found, here's how the compression heights differ:
383 piston: 1.433"
Stock 4.0L piston: 1.441"
This is probably close enough we could deck the block and get to zero deck, or close to it.
The purpose would be for a high compression 4.0L, possibly for race use or for use with a high octane fuel such as E85.
What do you think?
EDIT:
You know what, never mind. I just found this beauty:
http://www.kb-silvolite.com/spistons...tails&S_id=477
Old Jan 7, 2008 | 09:03 PM
F-tech.'s Avatar
F-tech.
or you could just put a stock 4.0 sohc piston in a ohv 4.0 and it brings it to about 12.3
to 1. And it won't hit
