05 idle issues
Old Sep 1, 2006 | 01:09 PM
rosa70's Avatar
rosa70
05 idle issues
Have an 05 exp that we purchased used. Had it at the dealership and they changed the motor mounts and trans mount to help the rough idle. New mounts are supposed to allow the engine to move more and not feel it in inside. Well its the same as it was before they changed the mounts.
My question is anyone with an 05 or up do you feel as though the engine is not as smooth as it should be at idle? Do you feel a miss in the engine? Have you ever put the truck in park and rev the engine up to about 2K and does it feel smooth. Our expy is vibrating at 2K in park.
Im bringing it back into the dealership on Tuesday but dont want them to say that is normal for the truck cause if they do Im going to go sit in an 06 and check it out myself while im there.
Any info will help.
Thanks
Old Sep 1, 2006 | 05:36 PM
aagitch's Avatar
aagitch
It should feel nice and smooth. I can't feel anything with my '03 idling or reving the engine. You must have a mis or something. Can't believe they changed the mounts. Shame on them.
Old Sep 1, 2006 | 07:24 PM
bridge's Avatar
bridge
Sick 'n Tired
I've got an '06 and yes it idles very rough. My '01 with 100K miles on it that I traded for the '06 idled 100% smoother than this car! I haven't had it to the dealer as yet, but I assume they will tell me it's normal. There are quite a few posts on this in a number of forums. They'll release a TSB on this issue sooner or later, and when they do my car will probably have 36,001 miles on it. My car also starts extremely hard.
Old Sep 1, 2006 | 07:27 PM
bridge's Avatar
bridge
Sick 'n Tired
I stand corrected...there is already a TSB on this...To the dealership I go!
Engine Controls - Cold Start Rough Idle Condition
TSB 06-5-1
03/20/06
COLD START ROUGH IDLE EXPEDITION 4X2 ONLY
FORD:
2005-2006 Expedition
ISSUE
Some 2005-2006 Expedition 4x2 vehicles may exhibit an idle vibration during cold start at 1400 RPM, that lasts for a few seconds. The symptom is perceived as shaking of the entire vehicle when the engine is first started after being off for an extended period of time in warm weather in excess of a few hours, such as overnight, with ambient temperatures greater than 60°F (16°C). The issue is not typically accompanied by unusual engine or fan noise. It is independent of air conditioning compressor engagement (bumps, bangs, or thumps) and air suspension pump operation (audible hum or buzz accompanied by an associated vibration).
ACTION
Use the following Service Procedure to resolve the concern.
SERVICE PROCEDURE
<TABLE cellSpacing=2 cellPadding=1><TBODY><TR vAlign=top><TD>1.</TD><TD>Using normal Workshop Manual diagnostics:
<TABLE cellSpacing=2 cellPadding=1><TBODY><TR vAlign=top><TD>a.</TD><TD>Verify the integrity of the fuel system (fuel injectors, fuel pump, fuel quality) and repair as necessary.
</TD></TR><TR vAlign=top><TD>b.</TD><TD>Check ignition system (spark plugs, ignition coils), mechanical engine operation, and repair as necessary.
</TD></TR></TBODY></TABLE></TD></TR><TR vAlign=top><TD>2.</TD><TD>Check the engine assembly exhaust mounting systems for ground-outs, damage, and repair as necessary.
</TD></TR><TR vAlign=top><TD>3.</TD><TD>If no concerns are found or cold start symptoms continue, reprogram the powertrain control module (PCM) to the latest calibration using WDS release B41.10 and higher or B42.1 and higher. This new calibration is not included in the B42 CD. Calibration files may also be obtained at the website.
</TD></TR></TBODY></TABLE>NOTE COLD ENGINE IDLE SPEED WILL DROP TO 1250 RPM AND WARM DRIVE IDLE SPEED WILL INCREASE TO 650 RPM. THIS CALIBRATION IS MATCHED TO THE SERVICE ENGINE/TRANSMISSION MOUNTS LISTED IN THIS TSB. DO NOT RE-INSTALL THE ORIGINAL ENGINE/TRANSMISSION MOUNTS AFTER PERFORMING THIS RECALIBRATION.
<TABLE cellSpacing=2 cellPadding=1><TBODY><TR vAlign=top><TD>4.</TD><TD>Replace the left hand and right hand engine mounts. Refer to the Workshop Manual, Section 303-01 - Engine Support Insulators
</TD></TR><TR vAlign=top><TD>5.</TD><TD>Replace the transmission mount. Refer to Workshop Manual, Section 307-01B - Transmission Insulator & Retainer</TD></TR></TBODY></TABLE>
Old Sep 1, 2006 | 07:42 PM
rosa70's Avatar
rosa70
4. Replace the left hand and right hand engine mounts. Refer to the Workshop Manual, Section 303-01 - Engine Support Insulators
5. Replace the transmission mount. Refer to Workshop Manual, Section 307-01B - Transmission Insulator & Retainer
This is what they did. They changed the mounts under this TSB. Still idles pretty rough for a vehicle of this caliber. My 99 dodge durango idle smoother than this truck and that had a distributor cap. Mine does it all the time and there stating this is a cold start problem. Does it all the time.
Old Sep 2, 2006 | 10:09 AM
kanertop's Avatar
kanertop
My '05 does this as well. I'm thinking this is a 3V issue. Does this occur in the F150 as well? I guess I should visit that forum as well.
Old Sep 2, 2006 | 01:08 PM
FRDTUF's Avatar
FRDTUF
My 04 idles rough as well . It ran smooth as silk for thefirst 10000 miles then all of a sudden it feels like it has a misfire at idle. Of course Ford had it 3 days and said one bank was lean so they changed the mass air and of course that did nothing,so I am feeling your pain here on this issue. I also cleaned my EGR and adjusted my TPS all to no avail.One thing I did notice was that all summer it seemed to idle fine,then the past two days have been colder (60's)and now it idles rough again. Its making me want to pull my hair out but I have none left. Lets all put our heads together and solve this once and for all.
Old Sep 15, 2006 | 12:10 PM
FRDTUF's Avatar
FRDTUF
Anyone with any ideas???
Old Sep 15, 2006 | 01:53 PM
rosa70's Avatar
rosa70
I was supposed to bring it back in last week but the wife needed the car. We are taking it in next week to have them look it over. Im having them check everything.
scsmartt
1997 - 2003 F150
13
Feb 22, 2015 09:15 AM
4EXTRDR
Jul 15, 2011 08:27 AM
MarkNtennessee
Sep 16, 2010 08:58 AM
V8EXPLR
2004 - 2008 F150
19
Jun 12, 2008 10:49 AM
bkampbel
25
Dec 10, 2005 12:07 PM
