6 speed overdrive gone
Man that statement just sent a shiver down my backbone Kris!
Like a bad case of De Ja Vu - all over again!
I'm constantly wirrying how my 4R100 aoto tranny will hold up to towing - but had in the back of my mind considered maybe if it failed somewhere down the track - rather than rebuilding it - I might buy ibn a new manual 6 speed and convert her..
Now with hearing about needle roller bearings again - I'm having second thoughts already, having walked this towing in overdrive rice paper trail once before as a younger towing ninja!
Cheers!
It is true that the far end of the countershaft, where the overdrive gear resides, is supported by a needle bearing (next to the reverse idler gear), and there is one inside the gear itself, the actual support for the shaft is in a tapered bearing situated in the spacer piece between the main box and tailbox, with another tapered bearing on end after third and fourth gears.
Why I have broken teeth is another question. I can't remember anything that could have caused this, so I guess I'll attribute it to stress. Maybe the extra torque from having a clutch that didn't slip pushed it over the top. That, and looking at the teeth, the overdrive gear has the smallest teeth, by far, of all the gears in the box. Maybe this is necessary due to the larger diameter of the gear, but they just seem less meaty.
Anyway, tomorrow I'm off to order a new gear, and then reassemble when it gets here. The only thing puzzling me is how to get the reverse and low gears off the mainshaft. The diagrams show a snap ring holding the ball bearing on the end of the main shaft (the driveshaft hub pushes right up against the race), but I can't find an end to grab. It looks like a continuous ring, so how do you get it out? It probably takes a special tool, which I will ask Ford about tomorrow.
I asked the mechanic to look at the pilot bearing marks, and of course, he said they were normal, just that the new bearing may not be riding in exactly the same place as the old. He even gave me another bearing if I wanted to change it again.
I'll post as soon as I get everything back together.
I'm going to see if I can get a look inside of my transmission somehow, perhaps through the PTO panel and then use a gooseneck light and a mirror.
With Christmas coming up, it won't be for a while I'm thinking, but I will definately return and report on what I found in mine as well.
Going on how you are describing it, I am guessing that you twist wrenches for a living.
The perfect example this summer was paying to have my clutch replaced. I should have done it myself, but just ran out of time preparing to go on vacation. Work has been extremely busy since we went through Hurricane Rita last year, and this spring and summer were even worse. And that was on top of doing repairs around the house (I live in Lake Charles, LA).
The irony was that when I talked to the mechanic yesterday, he told me that he was doing me a favor, because he knew we were leaving on vacation. That, and the fact that they got the wrong clutch the first time, and then had to scramble to get another one, pull the ttranny again and reinstall, so he said he wasn't surprised they left a few bolts loose. I guess it's alright to leave someone stranded on the highway, as long as you get their vehicle back on time. In my opinion, he just lost any credibility as a mechanic. Loose bolts are wrong, no matter what.
That just clinched that I won't put another vehicle in the shop. Then to top it off, my wife brought her Avalon to the dealership to get her first oil change last Thursday, and they forgot to tighten the plug that drains the oil filter housing. When she returned from a 150 mile roundtrip, she had 3 quarts left. Then they had the nerve to call for a customer satisfaction survey yesterday. You can't even trust people to do simple things anymore. I guess I'll be doing every oil change like her last car (95 Camry with 150K), that my daughter now drives.
I think I'll follow Kwiks advice and pull the PTO cover.
I too lost teeth on one occasion on a cog. 3rd gear from memory.
The thing is, when these parts fail, it's usually for a reason.
The reasons can be many - abuse, faulty manufacture or installation or even 'poor / bad' design at the outset! (Engineers never make mistakes?).
How do you know - that the stresses which destroyed the cog (in more than one place) didn't also overstress and bend out of thru the shafts - or overstress the bearings or their housing and so on!
What about the bits of metal that went thru the box, where did they go and what possible damage did they do to other components on the way thru?
Are you equipped to test every single component to know it is still within manufacturers tolerances?
IMHO - the broken cog is the end result of a problem - what you need to eliminate first is the cause of the problem.
You say that the needle roller bearings are fine and thats well & good, but do you know for 100% sure that the alloy housing hasn't stretched? Has the machined out bearing carrier become elongated and allowed the cogs to mis mesh at the wrong angle and hence destroy / break the weaker teeth?
Being an engineer, maybe you can measure - determine these things!
I would heartily recommend that you do, find that causal factor before investing a lot of $ into rebuilding that same transmission.
I'm not an engineer, but I did work for an engineering department for 10 years building and maintaining steel railway line, and in that time saw many many metal fatigue broken rails, some of substantial proportions - some that the ensuing train derailement accidents cost human lives even!
Maybe you can do some ultrasonic flaw detection on the remaining cogs & shafts etc, check them all for runout from true and so on!
That or start with a brand spanking new transmission from the ZF Factory....because somewhere in the one you have on your hands at present is a causal factor...that so far you don't appear to have identified!
Maybe even cast your eye over the engineering design - you've already alluded to the fact the teeth are very small in comparison to all the others!
Ask yourself the question...would the cog have lost it's teeth, if for example you always towed any trailers in direct drive (4th?) gear in the transmissions past history?
It'll be interesting - when you've had good time and opportunity to examine this from all angles, to hear what thoughts you eventually come up with for causal factor.
I for one look forward to your ongoing feedback - maybe we can all learn something vicariously from this!
For what little it's worth - I feel your pain!
Cheers!
Merry Christmas to All!
on edit:
maybe you will e able to get a mirror into that hole. just about 1 inch on either side of the shift slide.
