Auto power consumption
Old Aug 31, 2006 | 11:14 PM
Bdox's Avatar
Bdox
Does anyone have any real information about the power consumed by C-6 and C-4 transmissions? That is, as opposed to a manual.
I ask, thinking of building for milage.
Old Aug 31, 2006 | 11:40 PM
85e150's Avatar
85e150
Maybe a 5% penalty for the automatic.
Building for mileage....only an overdrive lockup torque converter automatic is going to compare favorably to a well driven manual with the right gears.
Of course, with the same axle, the OD auto will hose the non-OD manual, unless you already have 2.50 gears or something the auto won't pull in OD.
Many factors here, mostly the total weight of the vehicle, the aerodynamics, and how it's driven. Then we can quibble about the transmission.....
Old Sep 3, 2006 | 09:27 PM
Tsaven Nava's Avatar
Tsaven Nava
C6, I'd guess it eats around 30-35hp. The C-4 takes less, but it's also not as strong of a transmission as the C6, which is pretty bulletproof.Neither are going to get great mileage, as neither are OD. If you don't want to mess with computer controls, you might want to see about putting in an AOD trans, it's a 4-spd OD, not bad for light duty. If your not too worried about performance/towing capacity, that would likly be your best bet, but it depends greatly on the engine and vehicle.
The AOD-E is a newer variant, electronicly controlled with some other improvements, would require an aftermarket computer to operate.
Roger C
Feb 16, 2017 09:57 AM
Mike-fire32
Large Truck
Jun 5, 2013 09:58 AM
hazer
May 30, 2013 08:17 PM
reaydanny
1997 - 2003 F150
Jul 16, 2012 05:37 AM
big block power
Dec 21, 2002 01:37 AM
