Flashing battery light
Guessing I have a "going bad" alternator
symptium - The battery light on the dash s intermittently flashing at varoius brightness and frequency.
the truck is a 1989 F250 with a 7.3 diesel
can anyone help point me in the right direction to confirm and suggest a replacement as I would like to increase the output and go to an internal regulator.
Thanks
Ken
I do not have any direct experience with retro-fitting your engine with a larger alternator. I though since it was a diesel, you already had a large alternator?
With me present they took both the alternator and regulator off and put it on a test setup. Found that the diode pack has a bad diode, and the brushes are "lucky to be working". I watched then take it apart and there was also a lot of play n the bearings maybe 1/8 inch on the front and 1/16 on the back. The alternator is a 70 Amp.
The tech suggested that either it be rebuilt for $110 or a new 130 amp for $155 so I am going to go for the 130 amp. The 130 amp also has a (1 wire) regulator attached.
Does anyone have a wiring diagram of the alternator and external regulator so I can figure out how to adapt it. The truck is a 1989 F250 7.3 diesel
Thanks
Ken
http://www.autozone.com/images/cds/g...3d800a3a5b.gif
Thanks you for helping me on this issue but more importantly thank you for helping all of us in this forum who relay on people like you and your knowledge to make things work. It is through your participation this forum is what it is.
