Sponsored by: Auxito
Batteries
Old Aug 31, 2006 | 06:42 PM
vf150's Avatar
vf150
Question Batteries
Another question: I am looking into alternative batteries. I have read in other posts about motorcraft batteries being a good replacement battery but am thinking about Optima. Anyone have any good or bad info? Thanks.
Old Aug 31, 2006 | 08:51 PM
Ultramagdan's Avatar
Ultramagdan
I've used a Optima battery and it worked fine. The only issue is that many of the batteries today are very good and is it worth the price for the Optima when a replacement is cheap?
Old Aug 31, 2006 | 10:57 PM
bigdaddyII's Avatar
bigdaddyII
Totally agree with Ultramagdan. Good long lasting batteries are too cheap to be messing around with Optima.
Old Sep 1, 2006 | 04:33 PM
MrBSS's Avatar
MrBSS
Yeah, actually the Walmart batteries were best rated in the last Consumer's Report (I don't think they considered the Optima). But, the Optima might be worth considering if you drive off-road or otherwise shake up your battery. Its spiral construction is stronger than the usual grids, but the cost is approximately double. Worst case, you'd probably still be money ahead in buying a second conventional in a few years.
Old Sep 1, 2006 | 07:16 PM
vf150's Avatar
vf150
Talking Thanks for the input!
Thanks all for your input . I still don't know what I'm going to do . I will be checking on the deals for all of the batteries and check more on them. I understand that the optima doesn't leak or have the acid leak around the terminals. I hate that .
Thanks again.
Old Sep 2, 2006 | 09:52 AM
7700Rob's Avatar
7700Rob
If you rough house with your truck alot, it might be worth it, other wise not. I 'm a diehard Motorcraft battery fan.
