Offroad & 4x4
Bigger Tires?
Old Aug 31, 2006 | 03:01 PM
90efi's Avatar
90efi
Bigger Tires?
Does anyone know the what would be the biggest size tire you could install on a truck without lifting it would be? My truck is an 83 f 150 4x4.
Old Aug 31, 2006 | 03:16 PM
fishmanndotcom's Avatar
fishmanndotcom
52" michelins! they arent true to size so they should fit
-cutts-
Old Aug 31, 2006 | 03:24 PM
90efi's Avatar
90efi
Come on man 52''! They would rub the fenders wouldnt they? This is for a stock size truck.
Old Aug 31, 2006 | 05:17 PM
MBBFord's Avatar
MBBFord
It all depends on how much fender trimming you do...
But for no cutting or lift, you might be able to fit 33s with alittle rubbing, or 32x11.50s.
Old Aug 31, 2006 | 10:23 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Ditch the fenders and bed completely and run 53's!
Old Sep 1, 2006 | 12:24 PM
90efi's Avatar
90efi
Yeah maybe I'll try 33s. I dont really want to chop my fenders being there new. Maybe I should consider some lift. Whats the best kit out there for the everyday poor mans wallet?
Old Sep 1, 2006 | 12:48 PM
74fordtruck's Avatar
74fordtruck
just go with an 8" body lift. YOu can really make them as tall as you can, just find things to shove between the body and frame, and some really long grade 3 bolts (bolts are like golf. the smaller the number the better). then you'd be totally set for some 35's, and it wouldnt even touch the wallet.
(THIS IS NOT A SERIOUS POST!!!! DO NOT ACTUALLY ATTEMPT)
Old Sep 1, 2006 | 03:27 PM
grey77's Avatar
grey77
Ignore post.
Old Sep 1, 2006 | 03:29 PM
MBBFord's Avatar
MBBFord
You wouldn't want alot of lift. The main reason being if you plan on driving the truck with stock gears, don't go bigger than 33s. Then your acceleration, performace, and mileage would really drop with anything over 33s, and you will notice some of these with the 33s.
You could put a add a leaf in the rear for about 2" ($60-80)or if you want to go cheaper then do a shackle flip, and put new grade 8 bolts(just cost for the new bolts and that's it). Up front you can get some 3-4" lift springs on broncograveyard.com for about $115 and then you need some new C bushings(14 piece kit with trac bar bushings) $48, and a trac bar drop braket for about $30.
So say you do a shackle flip, and 4" lift all around, it cost about $200. Not to bad for 4"s and good room to clear those 33s.
If you have extra money, and don't like the way the truck turns or think the brake lines are to tight, then you could get a drop pitman arm for about $60, and some 8" hard brake lines with a coupler to connect your current line to the hard line for about $10 for both sides. OR get some real extended stailess steel lines for about $70.
Old Sep 1, 2006 | 05:02 PM
90efi's Avatar
90efi
That doesnt sound to bad. Im not to framiliar with playing with suspension. So my stupid question is by shackle flipping you mean to turn them upside down? Has any one got a picture of the results on their truck. Will this be okay for daily driving as in strength and durability and hauling items in the rear?
Old Sep 1, 2006 | 05:44 PM
ivanribic's Avatar
ivanribic
You don't want to haul really heavy loads on flipped shackles as they're designed to work in tension, not compression. A lot of weight will bend the ears and cause them to buckle. You can still haul stuff with your truck, you just want to watch the weight. Daily driving is fine and it'll actually make the truck ride smoother if you get the angle right.
See my shackle flip gallery here for pics and info: https://www.ford-trucks.com/user_gal...&albumid=13227
Old Sep 1, 2006 | 10:47 PM
god.boots's Avatar
god.boots
hows a load of firewood do with a shackle flip done right?
Old Sep 1, 2006 | 11:54 PM
aurgathor's Avatar
aurgathor
The rear should fit 33" just fine, it's the front that will more than likely rub. I would go no higher than 32", or get an about 1" spacer, or a leveling coil for the front.
Old Sep 2, 2006 | 12:30 AM
rebocardo's Avatar
rebocardo
31s will fit, 33s will not fit without a lift of some sort and since you carry firewood I would skip a body lift.
Old Sep 2, 2006 | 08:40 PM
90efi's Avatar
90efi
Thanks for showing those pics. But how about the front shackles? Any way to alter them without welding to a new plate?
