Backfire problems
Old Aug 30, 2006 | 05:45 PM
deadlylama's Avatar
deadlylama
Angry Backfire problems
I have an F-150 with a 400 in it. And Whenever I step on it it backfires. And I was wondering why this happens, and how to fix it. Thanks
Old Aug 31, 2006 | 04:51 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello, welcome to FTE!
Hesitation or flat spot can be either carb or timing. Make sure your distributor mechanical and vacuum advance is working properly. Make sure the carb accelerator pump is working.
There are threads here on how to test both of these systems. The carb forum has more carb info.
Unfortunately backfiring can destroy the power valve on the stock carb. The carb forum will have info on testing and replacement.
Old Aug 31, 2006 | 06:29 AM
Sycostang67's Avatar
Sycostang67
Have you messed with your plug wires lately? I did a tune-up on a 460 once and it started backfiring when I gave it gas, it turned out I had swapped 2 plug wires.
Old Aug 31, 2006 | 11:07 AM
Mil1ion's Avatar
Mil1ion
Does it backfire out the carb or out the tailpipe ?
Old Aug 31, 2006 | 04:54 PM
deadlylama's Avatar
deadlylama
It backfires out of the carb.
Old Aug 31, 2006 | 06:02 PM
Mil1ion's Avatar
Mil1ion
Check the distributor shaft for play sideways.
High mile parts like distributors show up re: problems different ways.
Back-firing out the carb can be ignition or fuel related.
Old Sep 2, 2006 | 06:41 PM
deadlylama's Avatar
deadlylama
Thanks for all your help. Its runing good now after I changed the plugs, wires and the distributor cap and rotor.
