Top Speed ?
Old Aug 30, 2006 | 04:23 PM
CHAMBO's Avatar
CHAMBO
Question Top Speed ?
I have a 03, 6.0 6 spd running 3:73 gears. 4" MBRP exhaust and Quadzilla intake.
Can anyone tell me at what mph the 6.0 will run with the limiter disabled ?
I'm looking for the number where horsepower can no longer overcome vehicle weight and aerodynamic drag.
Will the 6.0 hit the governed engine speed before reaching max mph?
A dodge started all this is all I will say for now.
Old Aug 30, 2006 | 04:41 PM
badbrad60's Avatar
badbrad60
I read in the Superchips tuner thread the Guru Vic Ferrari let it hang out at 141mph....
Old Aug 30, 2006 | 04:50 PM
tex25025's Avatar
tex25025
I had mine about 107 before i was dragging, but being that it's a dually i'm sure that caused it to start getting hard to increase speed quicker then a single axle truck. My old dodge got to 120 easy and that was with the governor still on(i didnt do any performance mods to that truck). I believe that even though the speedo goes to 100, I think it starts cutting back at 98 or 99 if you still have the governor on.
Old Aug 30, 2006 | 05:00 PM
6L PWR's Avatar
6L PWR
I hammered mine in Okalahoma on a long straight stretch and the speedo quit at 96 but the truck was still accelerating. The Edge Attitude was registering 128 before I backed down for a hill.
Old Aug 30, 2006 | 05:57 PM
tex25025's Avatar
tex25025
Thats strange, mine went all the way to 100 and then it quit. If my Outlook Monitor was correct, I was going about 107.
Old Aug 30, 2006 | 07:19 PM
npccpartsman's Avatar
npccpartsman
Mine goes back to zero after it goes over 100--lets talk RPM's with what rearend and what tire--at least we can get close
Old Aug 30, 2006 | 08:57 PM
CHAMBO's Avatar
CHAMBO
I guess what I would like to know is wheather the 6.0 will run up to it's engine goverened speed? Mine stops pulling at 97 - 98 mph, by the speedo. I still have a lot of rpm's left before I hit redline, but will it pull itself much faster if the limiter gets broken ?
I have a 99 with a 7.3, same gears and it will tach out at around 120. It will pull up to max engine rpm. ( not stock )
The rpms on the 6.0 were around 2750 when it shut down. Just doing a little in my head figuring, it looks like 125 should be a good number if it has enough power to pull it. Thanks for the reply's, much appreciated.
Old Aug 30, 2006 | 09:53 PM
Customz's Avatar
Customz
I recall stock having enough power for 125+ I believe Daryl Hunter did the calcs.
One user hit 154 with a custom tuned 6.0, exhaust and water/methanol injection. You need to run 100% torque convertor lockup in O/D for this. It was wound out over 4,000rpm and the egt gauge was pinned above 1600. Too bad the pics are gone.
Don't forget to fold in the mirrors.
Old Aug 30, 2006 | 09:58 PM
Customz's Avatar
Customz
https://www.ford-trucks.com/forums/3...ight=top+speed
Old Aug 31, 2006 | 05:37 AM
npccpartsman
That's the dude that tunes my truck. He knows soooo much more now that he did then. You should see what one does on just #2 when tuned correctly.
