Truck wouldn't run???
Old Aug 30, 2006 | 03:37 PM
Jed 16265's Avatar
Jed 16265
Hi all, new here today. Didn't know you existed, but glad I found you.
Looking for a little bit of help with a quandry I encountered this morning and would appreciate any thoughts you guys might be able to share. Thanks in advance...
I just received word from a mechanic that was looking at why my 1994 F-250 (7.5 litre V-8) wouldn't start.
He's telling me that with dual tanks, I have to have gas in both tanks, or the truck won't start and run. (Apparently, my father-in-law ran the back tank dry when he borrowed it.)
Now I may be thinking old school, prior to all of this computerized junk they use these days, but this just isn't computing with my brain.
Why would the truck care whether or not one tank has fuel if you're trying to run the truck off of the other tank and it's full?
Anyone out there know anything about this topic?
Old Aug 30, 2006 | 04:00 PM
subford's Avatar
subford
It should run just fine as long as you have selected the tank with fuel in it and the FDM is good in both tanks.
Old Aug 30, 2006 | 04:44 PM
Jed 16265's Avatar
Jed 16265
Subford,
Thanks for the quick reply. That's exactly what I would have thought, but what I've outlined, is what I'm being told, and it just didn't make sense.
I thought perhaps, it was somehow tied into the emission control system and the computer or something?
By the way, what is an FDM?
Old Aug 30, 2006 | 05:18 PM
subford's Avatar
subford
All the Computer does is ground the coil of the fuel pump relay, then check on its output (the relays) and does not know if you have fuel in the tank or what tank you have selected.
The only connection of the emission control system is the tank vents and they vent to a carbon canister.
The FDM is the Fuel Delivery Module, Here is a diagram of it:
http://i54.photobucket.com/albums/g91/subford/Fuel/FuelDeliveryAssembly2.gif
Old Aug 30, 2006 | 06:12 PM
quicklook2's Avatar
quicklook2
i have run my rear tank in my 94 dry and it ran off the front tank with no problem.
you never say if truck now starts or does not start.
Old Aug 30, 2006 | 11:37 PM
Jed 16265's Avatar
Jed 16265
Quicklook,
The truck is running again. I'm not sure I entirely understand the cause even after discussing it face-to-face with the mechanic, but I'll try.
Apparently, there is some type of check valve between the two fuel pumps and tanks. If you run either of the tanks dry and try to switch tanks, the valve can become dry and as a result get stuck.
If I understood him correctly, in this scenario, it continues to try and pull gas from the empty tank, as the valve having been stuck in place is blocking access to the full tank.
They claim they put gas in the rear tank messed with it enough to get the gas up to and moisten the valve. After they were able to accomplish that, the truck started and has been running good ever since.
Who'd have thunk???
Old Aug 31, 2006 | 07:53 AM
subford's Avatar
subford
On a 1994 there is not any check valves between the two FDM but you said pumps. The pumps are inside the FDM and the check valves are also inside the FDM on the output side of the pump. At this point the fuel pump would put up to 90 psi on the check valve to open it. If they had to play with it "???" I would not think the check valve is in good shape. If they did not change the FDM I would think this tank is going to start filling when you run your truck off the other tank.
Not possible, there is no way it can block the other tank.
Who'd have thunk???
Would you like to buy some ocean front property in Arizona?
Did they charge you anything for all of this BS.
I think I would find another mechanic, as these mechanics do not know what they are talking about.
Here is a diagram of your fuel system.
http://i54.photobucket.com/albums/g91/subford/Fuel/FielSystem.jpg
