brake conversion question
Old Aug 30, 2006 | 03:03 PM
CrazyAirman's Avatar
CrazyAirman
Unhappy brake conversion question
Hi all, I am comverting my 74 F100 4x4 from drum to front disc brakes, and thought I had it all worked out, using all parts from a 78. Here is my issue: the old metering block had 4 lines total, two inlet, and front and rear outlet. I purchased a new OE prop valve from J.B.G. and it has two inlet, one rear, and two front outlets. Yet the lines I bought have left and right on the diff, with one flex line that runs to the frame/ prop valve. What am I mising here? is there a two to one distribution block between these lines? or do i just block off one of the ports to the front?
I dont have a donor, or access to a 78/78 to look at, so I am kinda lost here.
any help would make my day MUCH better...! Thanks!
Old Aug 30, 2006 | 03:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
Just block off one of the front ports.
Old Aug 30, 2006 | 03:25 PM
CrazyAirman
Thats what I was thinking, but wanted to hear it from someone in the know!!
Thanks again!!!
Old Aug 30, 2006 | 03:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
The front ports are just an internal "Tee".
Old Aug 30, 2006 | 03:49 PM
Mil1ion's Avatar
Mil1ion
That's pretty expensive at JBG,
I found this one
http://www.inlinetube.com/Prop%20Valves/VFL101.htm
plus another at another FTE sponsor NPD for $165.00.
It seems they are finally making them (the stock type) available.
It's too bad they are so darn expensive
Here's an illustration of an 78 BPPV.
Old Aug 30, 2006 | 04:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
Half that price is for liability insurance...
Old Aug 30, 2006 | 04:42 PM
CrazyAirman
Jeff's bronco was also 165.00..... ( thought they were a sponser..?? my bad for not double checking )
I saw the aftermarket one, but had an uneasy feeling about it, so thought it would be safest to stick with OE.
Thanks for the diagram!
Old Aug 30, 2006 | 05:53 PM
Mil1ion's Avatar
Mil1ion
JBG is a sponsor
I was really just pointing out that more people have the STOCK units now and prices vary.
