Towing Problem - Weird Noise
Old Aug 30, 2006 | 02:58 PM
scottjestes's Avatar
scottjestes
Last week I was pulling about 7,500 lbs up the Hwy 20 grade from Grass Valley to Donner Pass (2003 PSD, stock, 55K mi) - ambient temp was about 95 degrees and I was pushing the truck pretty good (this was about the fourth hour of the trip back from Ft Bragg on the coast). I noticed that the fan had gone into high gear - I was probably going 55-60 mph with the truck in "tow mode" - tach speed was probably around 3K. I heard this weird sound - something like a "whrrrr-crunch" - that immediately made me think that the fan was slipping and then catching again. I looked at the gages and saw an elevated temperature - not in the red, but significantly above average. I took my foot off of the gas and got three "whrrr-crunches" in response, but within a minute the temp was back to normal. I backed off the accelerator and made it to the top of the ridge where I pulled over and let the truck idle for about 10 minutes before taking off again. No repeat problems. Anyone know what might have happened?
Old Sep 1, 2006 | 10:53 AM
Kep4's Avatar
Kep4
Jäger
I don't know the answer but a 'boost' up may get an answer from someone who does.
Old Sep 1, 2006 | 11:13 AM
2005 Ford's Avatar
2005 Ford
my trucks fan dosent make a crunch sound when it comes on but the darn thing sure likes to get hot like you described whenever i pull a trailer ( about 2-3 needle widths below the "hot" line), and im only towing 3000lbs!
Old Sep 2, 2006 | 10:59 AM
BowTieHatr's Avatar
BowTieHatr
well it could have been the fan clutch. towing 7000 lbs you might not need to activate the tow haul mode.
Old Sep 5, 2006 | 11:50 AM
scottjestes
Fan Clutch Details
Thanks for the replies. So, BowTieHatr, the supplemental fan does not kick in unless the Tow/Haul mode is engaged? Will have to try that next time - will be climbing up the killer west side into Yosemite in a couple of weeks. The noise was pretty weird, but definitely like the fan went to overspeed, then some crunching noises like gears trying to re-engage. I assume the temporary elevated engine temperature was because the fan did not re-engage properly.
