General Automotive Discussion
How do I disable fuel cutoff
Old Aug 30, 2006 | 12:19 PM
454mag's Avatar
454mag
Anyone know how to disable the fuel cutoff on a 92 grand marquis with the 4.6. I am prepping the car for figure 8 racing and plan on getting hit a lot. Can I just jump the two wires going to the switch in the trunk or is there more to it.
TIA
Old Aug 30, 2006 | 03:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
Just jump the wires or wire the pump direct from your ignition ON switch. Remember the oil pressure switch will also disable the engine and the pump thru the computer. There is a lot to setting up a car so it will take a hit, ask some of the old pro's at the track how it is done.
Old Aug 30, 2006 | 09:03 PM
Casey's Avatar
Casey
Not on a Ford. GM does this, Ford does not. All the oil pressure switch does is run the gauge.
Old Aug 30, 2006 | 09:35 PM
Mil1ion's Avatar
Mil1ion
I think Eric means a special installed Oil Pressure actuating switch T-ed into the O/P sending unit ... like you would put on a carbed engine with new electric fuel pump.
Old Aug 30, 2006 | 10:14 PM
Torque1st's Avatar
Torque1st
Posting Legend
Actually Ford does it on all the models I have worked on. Some by hard wiring and some thru the computer. Some computers thru an oil pressure switch and others thru counting ignition pulses. I don't know 100% but I believe it is part of Federal crash safety standards.
There is more info here in this 2001 change document and it points to other older documents. It is the first one I found with a brief search. There are many more. The rules were effective starting in the 70's. http://www.nhtsa.dot.gov/cars/rules/...PRM/Index.html
Old Aug 31, 2006 | 11:51 AM
GLR's Avatar
GLR
Go to the inertia switch in the trunk (driver's side) this is the button that pops up if you are in a collision. Cut the 2 wires going to it, strip the insulation, and wire nut them together. and that's it. Do it all the time around here for demolition derby cars. The 92 and up crown vics and grand marquis are doing fairly well in this area.
Old Sep 5, 2006 | 06:10 AM
454mag's Avatar
454mag
Thank you GLR
Did that and car ran great. Got 3rd in a 40 car enduro race but was taken out early in the demo in a hard head on collision after only 8 or ten othe r hits.
Old Sep 5, 2006 | 06:08 PM
GLR's Avatar
GLR
Head-ons hurt....for the future ...if the demo people let you...get rid of that aluminum bumper and put on a steel one off a 87 or older. Onr bolt out on each frame rail and the shock mount will slide out and replace it with the older bumper. Sell the aluminum one for scrape. Pull the wiring harness from up front and put it in the back towards the firewall. Get rid of the blower motor and A/C unit and make up a bracket to put the battery there. Or if allowed to, put the battery on the floor of the passenger side, or I have seen some withe the pass seat cut out so the battery sits inside the seat.
Old Sep 6, 2006 | 04:57 AM
Torque1st's Avatar
Torque1st
Posting Legend
There are a lot of tricks to making a derby racer more crashworthy. Get rid of anything that can disable the vehicle. Keep all the "vitals" as far from the crash zones as possible.
Old Sep 6, 2006 | 06:04 AM
454mag's Avatar
454mag
Had to leave the bumper stock. I did weld the bumper shock absorbers and relocated the battery to the passenger floor. Also welded all doors around the perimeter. Not much was going to help when the left front wheel was against the firewall and the a arm was sticking through the block. They will let you relocate the fuel tank to the trunk but it has to be a fuel cell ---- way to much work with a F.I. car with the pump in the tank.
Thanks
Ted
Old Sep 6, 2006 | 07:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
A-Arm thru the block, that is a bad hit...
Old Sep 6, 2006 | 07:37 AM
Bob Ayers's Avatar
Bob Ayers
GM products need this feature!!!!
dyoungen
Oct 7, 2011 09:20 AM
Fezziwig
Feb 8, 2009 12:13 PM
sckent
1983 - 2012 Ranger & B-Series
Jul 9, 2005 06:34 PM
jimzabiker
May 30, 2005 08:18 AM
79250
Apr 12, 2004 04:43 PM
