power brake problem
Old Aug 29, 2006 | 11:42 AM
RCrawler's Avatar
RCrawler
power brake problem
79 F150 2wd.
When I start it, the pedal draws down and holds some pressure on the brakes. Vacuum is hooked to a manifold vacuum source. Is this a symptom of a bad booster? I have never seen one do this before.
Jason
Old Aug 29, 2006 | 12:17 PM
Mil1ion's Avatar
Mil1ion
Booster test:
Shut engine off
Pump brake until all vacuum has been evacuated
hold pedal to floor while starting engine.
what does the pedal do ?
RE: for reference on newer thread this has been linked to older thread.
Posts #20,23,25
https://www.ford-trucks.com/forums/4...t=booster+test
Old Aug 29, 2006 | 12:21 PM
1975Ford's Avatar
1975Ford
To test power booster, http://www.classicperform.com/TechBo...tm#testbooster
probably the diaphram in the booster is leaking.
Keep us posted of your results.
buck
Old Aug 31, 2006 | 11:03 AM
RCrawler's Avatar
RCrawler
Did all of the tests listed for the booster as well as tested the check valve. All check out ok. Pinched off vacuum source and the pedal returns as normal.
I'm guessing that the internal valving in the booster is leaking, which is causing it to assist even without the brake pressed. I've seen a lot of failed boosters, but never this way. I'm hoping that I have a spare something on the shelf that will work. I had a 76 parts truck a couple of years ago that I wish I had kept. I could have used a lot of parts from it for this project.
Jason
Old Aug 31, 2006 | 12:54 PM
1975Ford's Avatar
1975Ford
That the way it seems it goes sometimes, you got all these parts sitting around, but then you let some parts go to friends or neighbors, and then it seems the part that was sold or donated is the part which is needed.
It does seem like the internals of the booster are worn.
buck
Old Nov 11, 2006 | 10:36 PM
J Hodges's Avatar
J Hodges
We had to replace the booster on my 1976 F-100 because it was doing the same thing
Old Nov 16, 2006 | 06:04 PM
1975Ford's Avatar
1975Ford
Thanks for posting.
RCrawler, have you found the problem?
Old Nov 16, 2006 | 07:58 PM
RCrawler's Avatar
RCrawler
I swapped brake boosters with my 77 which cured the problem. There is a seal that holds off vacuum from the back side of the booster until the pedal is depressed. Vacuum was leaking by this seal which was pulling the pedal down to hold just slight pressure on the brakes.
Jason
Old Nov 16, 2006 | 08:04 PM
scottie2hottie's Avatar
scottie2hottie
The boosters seem to be weak on these trucks(probly from age) seems like I'm replacin em left and right with all different syptoms.....
Tuxedo Scorpion
6.7L Power Stroke Diesel
28
Mar 18, 2012 07:13 AM
Jason T
Nov 12, 2004 10:17 PM
PoolBoy
Jun 30, 2004 04:22 PM
Jrock909
Jun 15, 2003 09:15 PM
