POS ranger need help asap
Old Aug 29, 2006 | 11:17 AM
TCANFIELD's Avatar
TCANFIELD
Exclamation POS ranger need help asap
it taps like a lifter but you can unplug a vacuum hose on the side of the intake it quits. It misses if you give it over 1/3 throttle and backfires. I put new plugs and wires. it runs decent after 3000 rpms though any help???
Old Aug 29, 2006 | 11:44 AM
TCANFIELD's Avatar
TCANFIELD
i found the tapping. It was the egr Valve. unpluged it and it quit tapping so i will replace it asap. but still runs like crap
Old Aug 29, 2006 | 12:05 PM
monsterbaby's Avatar
monsterbaby
well the egr valve could be creating a vac leak and making it run bad. since you know thats bad replace it and see what happens.
Old Aug 29, 2006 | 12:21 PM
BSmitty's Avatar
BSmitty
Yup, always fix known problems before trying to diagnose things, one of the golden rules of diagnostics!
Old Aug 29, 2006 | 09:04 PM
Greywolf's Avatar
Greywolf
I always look for vac leaks with a can of starting fluid or brake cleaner spray (ether)
Old Aug 30, 2006 | 08:34 PM
TCANFIELD's Avatar
TCANFIELD
ok i will try that then let yall know
Old Aug 30, 2006 | 09:41 PM
TCANFIELD's Avatar
TCANFIELD
ok i think i found the prob., maby???? the coil pack??? i can pull up 3 of the wires and the fire jumps but the other wire doesn't jump. it does make a difference in the missing so it is firing a lil.
