Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Generator question
Old Aug 28, 2006 | 08:00 PM
JMorton's Avatar
JMorton
Generator question
I have a Craftsman portable Generator I use when dry camping. It is only 20 amp so it trips the breakers if I try to use the A/C on the camper. Is there a way to bump it up to 30 amp? Is it as simple as a breaker change or can I even get a 30 amp breaker for it?
Old Aug 28, 2006 | 08:24 PM
helifixer's Avatar
helifixer
A 30 amp breaker would most likely smoke the stator windings or the wire to the plugs. When I pull a full 20 amps on mine it is nearly smoking the wires. So I wouldn't recommend upping the amps any.
Old Aug 28, 2006 | 10:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
Buy a larger generator. There is no way to bump the output without burning the unit up.
Old Aug 30, 2006 | 04:45 AM
Crash687's Avatar
Crash687
You need a good sized generator to start an A/C compressor, the inrush start up current can be up to 5 times the rated load amps. Having a hard start installed on the A/C compressor can help out when you have a high voltage drop off when starting.
Check to see what inrush rating of the generator is.
