Need help with this one
Old Aug 27, 2006 | 03:09 PM
salmonbob's Avatar
salmonbob
Hi Guy's.
My speedometer has started to work intermitedly and when it does'nt work, the overdrive starts blinking. When that happens, I re-start the truck and if I am lucky on the first try, it starts working.
I show no codes either. Has anyone had this same problem?
Thank you
Old Aug 27, 2006 | 03:13 PM
ssnh's Avatar
ssnh
searching yields vehicle speed sensor
Old Aug 27, 2006 | 03:24 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yep, im pointing at the vehicle speed sensor. it's located on the top of the pumpkin on the axle. here is a pic.
Old Aug 27, 2006 | 03:30 PM
BuickTurbo's Avatar
BuickTurbo
Jeez Stroke, you blow a seal or sumpthin'? Is that just tarcoat all over the...well everything?
Old Aug 27, 2006 | 04:04 PM
PowerstrokeJunkie
thats Rustoleum buddy.
i undercoated the rear of my truck last winter. plan on doing the center and front this winter some time.
Old Aug 27, 2006 | 04:37 PM
BuickTurbo's Avatar
BuickTurbo
Bring on the salt and sand season! A hundred years from now the only thing left of your truck will be the frame and undercarriage.
Old Aug 27, 2006 | 10:47 PM
ccg711's Avatar
ccg711
if you go looking for the VSS, it isn't always called the VSS in parts stores. I got mine fro o'reilly's and they had to look up RABS (Rear ABS sensor). take it with you for insurance. this sensor measures rear wheel velocity for any and everything the computer needs, ABS, cruise, speedo, etc. seems like mine was borg-werner RABS101 or something. when the looked up VSS it was completely wrong, but i had exact same symptoms. $20 or so, one of the cheapest and easiest parts you'll replace.
Chad
