06 KR rattle/vibration
Old Aug 27, 2006 | 01:17 PM
DASTUD's Avatar
DASTUD
When I go over small bumps, it sounds like my brake pedal and gas pedal are real loose. It is a loud rattle from somewhere under the dash on the driver side. I do not remember this always happening until late. Any ideas??? Any solutions??
Old Aug 28, 2006 | 09:23 AM
spd080's Avatar
spd080
most likely the emergency brake spring, mine does it occasionally. drive me crazy.
Old Aug 28, 2006 | 09:35 AM
455 Jet's Avatar
455 Jet
Check for anything under your seat. I had something rattle on the seat mounts to the floor, drove me nuts. It was the stinger for my hitch.
Old Aug 28, 2006 | 03:54 PM
DASTUD's Avatar
DASTUD
Thanks for the info, i would of never thought to look under my seat. Hopefully something is there. I will also check the e-brake spring.
Old Aug 28, 2006 | 09:17 PM
96f150's Avatar
96f150
Also, If you have the adjustable pedals, check them out
Old Aug 28, 2006 | 11:03 PM
DASTUD's Avatar
DASTUD
Thanks again.....my adjustable pedals do rattle slightly, but this was not the main rattle. I did find out what it was, my K&N intake. The hose clips that were holding the filter on at the end of the intake tube was bouncing up and down and hitting the heat sheild. This was sending a vibration through the fire wall. I put a rubber gasket around the hole in the heat shield and it fixed the problem. Now I do not have a vibration when I punch it either, which was kinda annoying, but i thought it was just normal. Anyone with the K&N that is having any type of vibration, check the above.
