Knock in Motor
Old Aug 26, 2006 | 10:32 PM
onebadf250's Avatar
onebadf250
Knock in Motor
I've noticed a knock coming from the motor. It only does it when I get down to a 1/4 of a tank of fuel. I can go fill up or get it up to 3/4 and the knock will go away. I'm kind of wondering if I have some water in my tank. With all this hot humid weather we have been having here in NWFlorida I'm wondering if I'm getting condensation in the tank.?.?
Has anyone else experienced anything like this? I've drained my water sepreator a couple of times, even though the H2O in Fuel light has not come on any. I also replaced the fuel filter today....which I usually do every other oil change. I did try to strech this one to 15K. It was black when I pulled it out. Won't do that again!
Thanks for the help.
RH
Old Aug 26, 2006 | 11:30 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
it is most likely air in the fuel. correct that statement, it IS air in the fuel. due to the shotty design of the fuel pickup mechanism in the tank, it will enable air to be pulled into the pickup assembly when there is less than 1/4 tank of fuel. the air then goes through the pump, and into the heads, where the only way out is through the injectors. the sound it makes is a small hammer tapping on the engine block. is that what you hear? the common fix for this is (research these) in-tank and prepump mods/ Hutch mod. however the cheaper of both is to keep the tank above 1/4
Old Aug 27, 2006 | 02:17 AM
1997F-350's Avatar
1997F-350
air in injectors not a pretty thing!!!
Old Aug 27, 2006 | 01:39 PM
onebadf250's Avatar
onebadf250
Yes, a small hammer tapping noise is what it sounds like. I usually do keep the tank above a 1/4 but have let it run down a few times here lately. I figured it was something like air or water one. I have heard of those fuel pick-up mods here on in the forum and yes I agree it is cheaper and less head ache to keep fuel in the tank.
Thanks for the reply.
RedDevil460
53
Mar 29, 2014 08:16 PM
jsims813
Jun 24, 2012 05:45 PM
FxRiZBeAsTLy
Dec 11, 2010 10:45 AM
BobFlowers
4 Cylinder Engines
Dec 10, 2003 09:13 PM
