Will not start, just a "click"
Old Aug 26, 2006 | 09:53 PM
ebraunusa's Avatar
ebraunusa
Hi all --
My 98, Expedition with 4.6 is not starting and just clickings. I left home and I heard a click and then the truck started. I then stopped the truck and tried to start again and all I get is a click at the starter relay. I tried to touch both posts with a screwdriver with the key in the on and start position, but it will not start.
I also tried starting the truck with the headlights on. The headlights never dimmed.
I took the cables off the battery and cleaned them up, but not working. Finally, the connections on the starter has some corresion on it, but I have not been able to clean them up.
Is the problem with the relay, or the corresion, or the starter?
Thanks
Old Aug 27, 2006 | 12:07 AM
George Frasier's Avatar
George Frasier
Am not familiar with that model, but I'd guess it may be a bad solenoid (on/at the starter). Also could be a weak battery.
Old Aug 27, 2006 | 11:36 PM
Freak4Ford's Avatar
Freak4Ford
Clean your terminals on the starter, check your battery, and if its still not working then it very well could be your solenoid.
Old Aug 28, 2006 | 08:13 AM
ebraunusa's Avatar
ebraunusa
Truck Fixed
I had a bad starter. There is the wire from the solenoid to the starter that has no sheating on it. The wire was so corroded and was only holding on by a strand.
Eric
