Power Steering
Old Mar 21, 2002 | 10:24 AM
sgreen's Avatar
sgreen
Power Steering
No questions about converting to pwr. I have a pwr steering box from a 75 f250 donor. I think there are a couple different boxes that came on these trucks. How can I tell what make I have? What are some of the problems I need to be looking out for before I put this on my 66 f100. I am planning to put a seal kit in the box before I install it, are there any other recommendations or issues to be aware of?
Thanks in advance;
S
Old Mar 21, 2002 | 11:27 AM
jowilker's Avatar
jowilker
Power Steering
Scott as long as you have a 2wd ps gear box no problem with the gear. If you have 3 spd on the column, you will have to find a ps sd column out of a 71/72 to work with the gear. If you have an automatic you can get by with changing the column shaft or the whole column.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Mar 21, 2002 | 08:19 PM
66ranger's Avatar
66ranger
Power Steering
Don't for get, you need to reuse your column to dash bracket from your '66 for any 67-79 steering column swap.(gently drill out the small spot welds to remove your '66 bracket)....
Old Mar 22, 2002 | 08:19 AM
evans's Avatar
evans
Power Steering
