Trans Slippage Question
Old Aug 26, 2006 | 07:43 PM
kiohio1985's Avatar
kiohio1985
Can the trans shift good at all times but slip in overdrive?
I don't notice anything unusual but on hills it seems to slow down at steady RPM's.
Or is something else going on?
Thanks,
KO
Old Aug 26, 2006 | 10:40 PM
andym's Avatar
andym
It's tough to answer that without any details about the truck.
Old Aug 27, 2006 | 02:57 PM
kiohio1985's Avatar
kiohio1985
I thought I had my sig showing, sorry.
97 F350 4x4 460 E40D
KO
Old Aug 27, 2006 | 03:09 PM
quicklook2's Avatar
quicklook2
mileage, service details etc. will help.
that is what andy was asking.
Old Aug 27, 2006 | 03:37 PM
kiohio1985's Avatar
kiohio1985
136k Just changed trans oil and filter.
Was shifting hard, now shifts fine.
KO
Old Aug 27, 2006 | 03:51 PM
quicklook2's Avatar
quicklook2
so now it does not slip?
did you drain convertor at the same time?
Old Aug 27, 2006 | 04:13 PM
kiohio1985's Avatar
kiohio1985
It shifts fine, but seems to slip in overdrive.
Yes I did drain the convertor.
No ugly stuff in the pan.
Wondering if there was something that controlled converter lock-up.
KO
Or something else that could be wrong.
I didn't notice it till after changing the fluid.
KO
Old Aug 27, 2006 | 04:48 PM
quicklook2's Avatar
quicklook2
did you use correct fluid? what brand?
is it full when you check it warmed up?
was filter installed with o-ring and pushed up correctly?
try resetting the computer.
is the button on shifter working correctly?
Old Aug 27, 2006 | 10:14 PM
kiohio1985's Avatar
kiohio1985
Valvoline Dexron III/Mercon
Trans Filter installed with o-ring and pushed all the way in, original filter fell out in the pan.
Computer was reset when trans fliud was changed, I put a new o-sensor in at same time.
Push button works and light doesn't flash.
I just chcked the fluid, it is approx a 1/4" little over full.
KO
Old Aug 28, 2006 | 10:17 PM
kiohio1985's Avatar
kiohio1985
It must not be good................
KO
