AC Question???
Old Aug 26, 2006 | 01:05 PM
wolfe1104's Avatar
wolfe1104
AC Question???
This maybe a stupid question, but my ac compressor should be turning when i have the defrost on, right? so that it dries out the air?
Old Aug 26, 2006 | 01:13 PM
Cuda_jim's Avatar
Cuda_jim
Yep, ac on with defroster.
Old Aug 26, 2006 | 01:15 PM
Uzumati's Avatar
Uzumati
When DEFROST is selected:
The air inlet door is in the no vacuum position, admitting outside air.
Both the panel/defrost door and the floor/panel door are in the no vacuum position so that most of the incoming air is directed to the windshield defroster hose nozzle. There is also airflow to the A/C side window demisters.
The temperature setting will determine the amount of air that is directed through the heater core and the amount that bypasses the heater core.
The A/C compressor will be enabled when DEFROST is selected to dehumidify the air and reduce windshield fogging.
The blower motor is on
Old Aug 26, 2006 | 02:58 PM
wolfe1104's Avatar
wolfe1104
Thats what i thought, i just wanted to make sure. I just noticed the ac dripping some water this morning while i was using the defrost. I checked and say the ac was running, but my dad was insisting that it shoudnt be.
